AnyConnect and licences
since Cisco has been telling us that AnyConnect is the upgrade path from the old IPsec client for x64 machines, I am wondering if you require WebVPN licences to use the AnyConnect client. ASDM reports the number of "clientless SSL VPN" peers, so AnyConnect should be a "client SSL VPN", but that is just guesswork... Can anyone confirm/deny this? And if AnyConnect requires licences, will it acquire IPsec functionality in the future, so we can move to x64 architecture without paying for SSL VPN?
Bostjan
blueoceanventure Fri, 07/20/2007 - 01:41
I read somewhere on cisco.com that IPsec functionality was coming to the AnyConnect later :)
shaun.white Sat, 07/21/2007 - 18:44
yes, you are correct...any connect is only replacing the SSL (SVC) client as of release 8.0
ggilbert Sun, 07/22/2007 - 07:55
  • Cisco Employee,
Bostjan,
The number of Webvpn license determine number of webvpn & SSL VPN (Anyconnect client) connections.
Anyconnect at the moment in 8.0.2 supports only TLS & DTLS options. In the next future release, it will support IPSec connectivity.
gilbert
