VPN and NAT on 871
Jul 19th, 2007
I'm having issues establishing a VPN on a 871 through a NAT.
The 871 goes through an ISP to another router across the internet. It has 4 VLANs configured, and the goal is to VPN one to a network through the internet. Obviously being the internet, the private addresses are all running through a nat on fa 4 (the WAN port on the 871)
In a test setup, I can successfully perform NAT, or the VPN but not both at the same time. The NAT seems to take precedence over the crypto map.
I've tried setting this up with both CLI and SDM, but neither way seems to work. Config below with working VPN but NAT turned off.
hostname Router1
resource policy
no ip source-route
ip cef
no ip domain lookup
crypto isakmp policy 1
encr des
authentication pre-share
group 1
crypto isakmp key testkey address 172.16.0.3
crypto ipsec transform-set VPN1 ah-md5-hmac esp-des
crypto map VPN 1 ipsec-isakmp
set peer 172.16.0.3
set transform-set VPN1
set pfs group1
match address 103
interface FastEthernet0
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN
ip address 172.16.0.254 255.255.255.0
duplex auto
speed auto
crypto map VPN
interface Vlan1
description INTERNAL_MGMT
ip address 192.168.1.5 255.255.255.0
interface Vlan10
description DATA_AND_VIDEO
ip address 10.31.255.252 255.240.0.0
interface Vlan90
description VOIP
ip address 10.32.0.252 255.240.0.0
interface Vlan100
description EXT_MGMT
ip address 10.48.0.252 255.240.0.0
ip route 0.0.0.0 0.0.0.0 172.16.0.3
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
access-list 103 permit ip 10.48.0.0 0.15.255.255 host 203.0.0.1
control-plane
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
login local
richard-o Thu, 07/19/2007 - 23:21
I finally coaxed SDM into making it work. Of course it worked, after disabling the desired VPN network from being through NAT.
What are my options with these things?
