07-19-2007 11:36 PM - edited 03-05-2019 05:24 PM
We are creating two VLAN with a 1800 series router for two branch office each 64 Kbps(Total 128 Kbps).Can Any one tell me the configuration command for creating the VLAN for the above.
07-20-2007 01:18 AM
On which port you are trying to create the vlans ?
are you trying to create vlans on the ESW module ?
if yes you can refer the below link for the same..
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a00808066b8.shtml
regds
Log in to Community
