07-19-2007 11:54 PM - edited 03-11-2019 03:46 AM
Hi Friends,
I have Pix 515E ,i am not able to access pix through https ,how to reset firewall to factory default. so that i can access firewall and starting managing.
Solved! Go to Solution.
07-26-2007 04:21 AM
Amit;
In order to configure/manage the Pix device through a Web browser, several things are required:
http server enable
http a.b.c.d n.n.n.n Outside
(where a.b.c.d n.n.n.n is the IP address of another network or host which you will be permitting to connect to the Pix from the Outside)
It is also advisable to add users to the local database (or use AAA authentication) in order to identify and authenticate yourself to the firewall.
Also, depending upon the version of the code on the firewall, you will also need to have MS Internet Explorer, and an appropriate Java runtime installed on the computer from which you will connect to the firewall. Version 6.x of the Pix code will use PDM, whereas Version 7.x will use the ASDM.
Please rate if helpful,
Carl
07-20-2007 01:40 AM
You need to connect via the console port using a rolled cable. If you don't have the password then follow the password recovery process.
http://www.cisco.com/warp/public/110/34.shtml
Then from privaliged mode run "write erase" to clear the config, or run "setup" to overwrite with a basic configuration.
** Please rate if helpfull **
07-26-2007 03:29 AM
Hi Mark ,
Thanxs for great help.but now i want access my firewall through web ,how would i do that ,kindly relpy.
Amit
07-26-2007 04:21 AM
Amit;
http server enable
Carl
