aaa accounting under acs
Jul 20th, 2007
I use acs 4.1 under "Reports and Activity" -> "TACACS+ Accounting" I can see some start/stop reportings.
But under "Reports and Activity" -> "TACACS+ Administration" I can't see anything...
What do I have to configure at least???
Thanx
bb
Overall Rating: 5 (3 ratings)
somishra Fri, 07/20/2007 - 02:10
  • Cisco Employee,
I believe you are hitting a bug. The bug ID is CSCsg97429: TACACS+ Command Accounting does not work in ACS 4.1(1) Build 23.
The patch for bug
CSCsg97429 is ready and files are available on cisco.com.
Hope this helps,
Soumya
elliott.fougman Fri, 07/20/2007 - 06:48
Ensure you have the relevant config on you routers switches. It should look omething like this
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ none
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
Hope this helps.
Elliott
j-mccarthy Tue, 10/02/2007 - 22:28
You guys rock !! This is my first time using this forum and you have solved a problem that had me tearing my hair out and questioning my sanity.
A BIG thank you to Somishra and Jghambir for your responses to this topic.
You are bang on with both the diagnosis and resolution.
Jagdeep Gambhir Fri, 07/20/2007 - 07:32
  • Red, 2250 points or more
BB,
This is a known issue, you need to apply patch ACS 4.1.1.23.5 to fix the issue.
Patch for appliance is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des')">http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des&lt
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
Jagdeep
Note: If that answers your question, then please mark this thread as resolved, so that others can benefit from it.
Jagdeep Gambhir Fri, 07/20/2007 - 07:34
Also make sure that you apply patch on remote agent else communication between acs and RA will break.
~JG
darpotter Sun, 07/22/2007 - 22:57
  • Silver, 250 points or more
If you encounter problems with the remote agent take a look at extraxi csvsync. This uses http to collect CSVs in bulk via CSAdmin and as such requires no agents or dedicated servers.
www.extraxi.com/csvsync.htm
