Specifying TFTP option in IOS DHCP
Jul 20th, 2007
Can u please let me know how to specify the tftp server IP address in the IOS DHCP server? I could not get enough information from the IOS documentation.
Gnanavel.
mohammedmahmoud Fri, 07/20/2007 - 03:34
  • Green, 3000 points or more
TFTP is DHCP option number 66, thus you need to add the following line under the DHCP pool;
option 66 ascii
[edit] I guess Narayan is correct, define option 150 if the TFTP server does not have an entry in the DNS server.
HTH,
Mohammed Mahmoud.
royalblues Fri, 07/20/2007 - 03:41
Mohammed,
It would depend upon what the user is trying to do with the tftp server.
I think if the user is concerned with returning the TFTP server address for DHCP clients such as IP phones we generally use option 150
Narayan
mohammedmahmoud Fri, 07/20/2007 - 04:27
Hi Narayan,
First of all, sorry for replying on your reply :) but as i told you before i am using a slowww dial-up link these couple of days, any way using option 66 needs a DNS entry for the TFTP server, and thus i agree with you that using option 150 is the most optimum method.
BR,
Mohammed Mahmoud.
royalblues Fri, 07/20/2007 - 05:12
No problems my friend, it happens all the time.
good to see you back anyway on the forum
Narayan
mohammedmahmoud Fri, 07/20/2007 - 06:51
hi Narayan,
Thank you my friend :), i missed the forum thats why i am back, but i think i'll have to go back to my lab in a couple of min to continue my battle, c u in a couple of days :)
BR,
Mohammed Mahmoud.
