each vlans to be allocated with bandwidth
Jul 20th, 2007
I have two VLANs connected to 1841 router.The WAN link is totally 128KBps. I want to dedicately allocate 64KBps for each VLAN. Is there any configuration command for the above scenario?can anyone send me configutaion files?
Overall Rating: 3 (1 ratings)
royalblues Fri, 07/20/2007 - 05:26
You can do something like this
ip access-list exrended vlan1
permit ip any
ip access-list exrended vlan2
permit ip any
class-map match-all vlan1
match access-group vlan1
class-map match-all vlan2
match access-group vlan2
policy-map restrict
class vlan1
police cir 64000 confirm-action-transmit exceed-action-drop
class vlan2
interface serial 1/0 --interface to WAN
service-policy output restrict
HTH, rate if it does
guruprasadr Fri, 07/20/2007 - 05:47
HI Narayan,
Thanks Again for sample Configuration.
Best Regards,
Guru Prasad R
