XENPAK-10GB-ER don't work with IOS 12.2(35)SE2.
Jul 20th, 2007
IOS 12.2(35)SE2 doesn't seem to recognize the XENPAK-10GB-ER hardware.
"Media Not Present" - If I downgrade the switch it recognizes the Xenpak. 12.2(25)SEE2.
purohit_810 Fri, 07/20/2007 - 10:04
  • Silver, 250 points or more
Which switch you have ?
This appendix lists some of the command-line interface (CLI) commands that appear when you enter the question mark (?) at the Catalyst 3750-E or 3560-E switch prompt but are not supported in this release, either because they are not tested or because of Catalyst 3750-E or 3560-E switch hardware limitations. This is not a complete list. The unsupported commands are listed by software feature and command mode
Dharmesh Purohit
