connecting firewall/servers
Jul 20th, 2007
Hi all, can anyone tell me what route people use to get to the firewall, would they plug it directly to the core switches and have a seperate vlan, and also when connecting servers, if they have 2 network cards teamed to 1, would I plug one into one distribution switch and the other card in another, what would be the best way for resiliance for the servers
many thanks guys
purohit_810 Fri, 07/20/2007 - 09:53
  • Silver, 250 points or more
People are using Static or default route with natting.
router {Eo}---> {Outside}Firewall{Inside}--> Access or Distribution switch.
Router: Default route to ISP
E0 natting indide
Firewall : Acl and Nat on inside to outside for both subnets.
Switch id L3/Distribution: Point to inside firewall
If L2 / Access: Create two Vlan - and connect it.
Dharmesh Purohit
