877 vlans routing
Answered Question
Jul 20th, 2007
Hi to all,
I have this problem, I need to connect a small office to adsl and to external LAN. So if I have a router with two ethernet (like 28xx) it's easy I put a "static route", but I can not permite a 28xx!!!
So I ask you: can I use a 877? Can I configure more than vlan on its 4 fastEth port? Use 1 port for a vlan and use it as external porta and the other 3 Eth for the default vlan as internal, associate to each of this vlans different IP address and put two static router?
If it is possible con you suggest some configuration or examples?
Thank you.
Augusto.
Correct Answer by mohammedmahmoud about 10 years 3 days ago
hi,
All that you've stated is correct except that you don't need static routes as the interfaces are directly connected on the same router, but you'll need a default route for the internet pointing to the ADSL.
Router# vlan database
Router(vlan)# vlan 2
Router(vlan)# exit
Router#config t
interface FastEthernet0
switchport mode access
switchport access vlan 2
interface FastEthernet1
interface FastEthernet3
interface FastEthernet4
interface vlan1
ip address
interface vlan2
ip address
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
purohit_810 Fri, 07/20/2007 - 10:11
  • Silver, 250 points or more
Istead of putting two different route... Put Default route.
As of your scenario it is atub network. So, you are good to do that.
U can create Vlan Maximum 4 Vlan.
Dharmesh Purohit
Correct Answer
mohammedmahmoud Fri, 07/20/2007 - 11:28
  • Green, 3000 points or more
hi,
Router(vlan)# exit
Router#config t
interface vlan1
ip address
interface vlan2
ip address
HTH,
Mohammed Mahmoud.
