Looking for Router platform recommendation
Jul 20th, 2007
Here are the requirements...
Router require the ability to terminate and map 200 VLANs to MPLS LSP
- This router will require the ability to receive and table up to 10,000 routes learned via RIP
- The router will require the ability to table an terminate up to 10,000 remote BGP peers
- This router will support up to xx concurrent VoIP sessions
thank you
ksnarayan43 Fri, 07/20/2007 - 06:50
Thank you .
How is it different from 12000 (GSR). We had issue with 12000 series routers processing 6000 RIP routes..
thanks
