Setup Failover Internet Connection on different subnet
Jul 20th, 2007
Hi all, I am new to this.
How can I set up an automatic (after two minutes) Failover Internet Connection on two routers?
Both, of course, are on two different subnets.
Both routers are 2621XM.
Overall Rating: 5 (1 ratings)
purohit_810 Fri, 07/20/2007 - 09:47
  • Silver, 250 points or more
You ca configure default route by using floating route.
Floating route same as followed by static route higher administrative distance.
Dharmesh Puorhit
ronyahmed Fri, 07/20/2007 - 10:11
ip route x.x.x.x x.x.x.x y.y.y.y
ip route x.x.x.x x.x.x.x z.z.z.z 200
The x.x.x.x is your source address and mask and y.y.y.y and z.z.z.z will be your destination routers. if you are defaulting everything to the internet the set of x's need to be 0's the 200 at the end of the 2nd route is the administrative distance. Now, if the y router fails and can't be reached the z will take over. You need to replace the X Y and Z values with your IP addresses in your environment
