T1-CAS cannot receive DID calls
Jul 20th, 2007
I have a mgcp gateway using a T1-cas line with 5 trunks. Outbound calling works fine, inbound calling gets dialtone and then fast busy. Dial peer configuration is as follows
dial-peer voice 5 pots
description T1-CAS
service mgcpapp
port 0/2/0:1
debug voice dial-peer shows dnis hitting gateway. Any help is appreciated
dgahm Fri, 07/20/2007 - 07:01
  • Blue, 1500 points or more
Pete,
Has this ever worked correctly?
If yes, then try a Call Manager gateway reset. I recently had a very similar problem that was resolved by reloading the router (2801).
If this is a a new install, debug cas, and work with the telco. Is this E&M wink?
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020ecf6.html
Please rate helpful posts.
Dave
balitewiczp Fri, 07/20/2007 - 07:50
no, it has never worked. it is a new install. yes, the ports are e&m wink start. I will try the document, and resetting gw. thx
Chris Deren Fri, 07/20/2007 - 07:08
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
How is your GW configured in CM, how many digits are you expecting, is the CSS configured properly?
Chris
balitewiczp Fri, 07/20/2007 - 09:03
i am expecting 4 digits, the gw and the phone are in the same css
