crossover cable
Jul 20th, 2007
Hi all, is there any reason why we use a crossover between switches ? why cant we use a straight through cable if they support full duplex ?
Overall Rating: 5 (1 ratings)
mohammedmahmoud Fri, 07/20/2007 - 07:04
Hi Carl,
Crossover cables are used between switches in order to connect Tx1 to Rx2 and vice versa (in order for the switches to exchange traffic), however there is a feature called AutoMDIX can do the crossover automatically but it is not supported in all switches.
HTH,
Mohammed Mahmoud.
mohammedmahmoud Fri, 07/20/2007 - 08:59
Hi Carl,
Hubs and switches are deliberately wired opposite the way end stations are wired, so that when a hub or switch is connected to an end station, a "straight through" ethernet cable can be used and the pairs will match up properly. When two hub/switches are connected to each other, or two end stations are connected to each other, a "crossover" cable is used to make sure that the correct pairs are connected.
HTH,
Mohammed Mahmoud.
