Syslog problem
Jul 20th, 2007
LMS2.6 on Solaris9. Not able to run syslog standard report or any other syslog functions. I have checked the following:
1. messages are coming to sylog_info (tail -f shows new messages arriving)
2. SyslogCollector is running, there are no filters and mode set to keep
3. Syslogcollector is registered and I'm seeing messages there too
What else should I check? Thank you in advance.
I have attached syslog.conf file
Overall Rating: 5 (1 ratings)
David Stanford Fri, 07/20/2007 - 07:37
Are the devices managed devices in RME?
Can you enable debugs for SyslogAnalyzer/SyslogCollector while sending a syslog message to see if it gets processed for the device?
Are the reports appearing as empty or error messages?
