Aironet 1130AG Help
Jul 20th, 2007
I have 4 Aironet 1130AG WAP's
How do I configure them to use WPA Without a RADIUS server?
I have got one of them set up by adding a VLAN and a SSID and used in encription manager I set Cypher to TKIP.
In SSID I have set Key management to mandatory checked WPA and set the WPA pre-shared key.
On my laptop I can see the SSID and it is listed as Security Enabled network (WPA)
When I try to connect and and enter the WPA pre-shared key it tries to connect and never does, but the connection changes to Automatic.
How do I get these to work?
andrew.brazier@... Tue, 07/24/2007 - 07:03
Unless you need VLANs for your network you don't need to configure any on the AP to make this work and that may be where your problem lies. Try removing the VLAN and see if that helps.
Connect_IT Thu, 09/27/2007 - 02:19
Have you been able to resolve your problem? I ask this because I have the same question about setting-up the 1130AG to use WPA without using a Radius Server.
