MPLS IP Interworking FR to VLAN?
Jul 20th, 2007
(I re-posted this question in the MPLS forum where it should be)
If I do Frame Relay to VLAN over L2TPV3 as the example in this document:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a00801b2407.html#wp1046329
Do I have to xconnect back to frame-relay to finish the circuit or can I use the "interface VLAN" somewhere else in the network and have the circuit to behave like a point-to-point even when in started as frame-relay.
Or the question might be better state as: If the client can have FR delivered on one side and Ethernet in the other?
-W
Overall Rating: 3.5 (2 ratings)
william.caban Thu, 07/26/2007 - 11:10
I'm confused, will this configuration will route the IP and would I be able to deliver pure IP or will I still need to do some type of frame-relay conversion in order to deliver it?
Pavel Bykov Thu, 07/26/2007 - 06:48
  • Silver, 250 points or more
FR emulation of some sort would have to be used. Alternatively, you can start tunnel on another interface, that is not FR.
william.caban Thu, 07/26/2007 - 11:12
How can I do this FR emulation? Is there a way or do I have to deliver to a FR interface?
Pavel Bykov Fri, 07/27/2007 - 07:01
We posted at about the same time with Gabriel.
What Gabriel suggested seems an exact solution that you require, as per Cisco document located at the link he provided.
