DHCP/ ip helper address not working with ACL
Jul 20th, 2007
For some reason the following ACL will not pass DHCP using ip helper address when applied to the vlan. The vlan is 172.20.148.0.23 The DHCP is on the 10.10.1.0/24 network. All works fine with no ACL. ACL works except for allowing DHCP.
Any ideas what I'm doing wrong?
config t
ip access-list extended net149C
?permit tcp any eq telnet any established
?permit tcp any eq 22 any established
permit udp any any eq bootps
permit udp any any eq bootpc
permit tcp any host 10.10.1.10 eq 80
permit ip any host 10.10.1.58
permit ip any host 10.10.1.105
permit ip any host 10.10.1.79
permit ip any host 10.10.1.90
permit ip any host 10.10.1.13
permit ip any host 10.10.1.18
permit ip any host 10.10.1.62
deny ip any 10.10.1.0 0.0.0.255
deny? ip any 198.146.193.0 0.0.0.255
?deny? ip any 192.168.5.0 0.0.0.255
?deny? ip any 192.168.6.0 0.0.0.255
?deny? ip any 192.168.7.0 0.0.0.255
?deny? ip any 192.168.21.0 0.0.0.255
?deny? ip any 192.168.70.0 0.0.0.255
?deny? ip any 192.168.4.0 0.0.0.255
?deny? ip any 192.168.20.0 0.0.0.255
?deny? ip any 192.168.40.0 0.0.0.255
deny? ip any 172.20.0.0 0.0.255.255
?permit ip any any
?exit
interface vlan149
?ip access-group net149C in
exit
end
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 07/20/2007 - 09:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Randy
Try changing
to
permit udp any eq bootpc any
Jon
You would need to debug the access-list:
1) Disable fast switching on the interfaces involved. You only see the first packet if fast switching is not disabled.
config interface
no ip route-cache
2) Use the "terminal monitor" command in enable mode in order to display "debug" command output and system error messages for the current terminal and session.
3) Use the "debug ip packet net149C detail" command in order to begin the debug process.
4) After your captures are done. Execute the no debug all command in enable mode and the interface configuration command in order to stop the debug process.
Restart caching.
config interface
ip route-cache
Reference:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#ts
bob.bartlett Mon, 07/23/2007 - 08:24
Try changing yours to this
permit udp any eq bootps any eq bootpc
jerrytozhang Fri, 08/03/2007 - 05:43
Hi,randyclark:
Try my access-list,it works well with my 1721/1751/1841 routers in my 200+ branches worldwide.
access-list 126 permit udp any host 255.255.255.255 eq bootps
access-list 126 permit udp any host 255.255.255.255 eq bootpc
Thanks.
