TFTP Server Which Supports Files Larger Than 32 Megs
Answered Question
Jul 20th, 2007
  • Silver, 250 points or more
Anyone know of a TFTP server which supports files larger than 32megs?
We are trying to upgrade a Wireless Controller from 4.0 to 4.1 and this was in the release notes:
Controller software release 4.1.171.0 is greater than 32 MB; therefore, you must make sure that your
TFTP server supports files that are larger than 32 MB. Some TFTP servers that support files of this
size are tftpd, Cisco tftp, and the TFTP server within the WCS. If you attempt to download the
4.1.171.0 controller software and your TFTP server does not support files of this size, the following
error message appears: ?TFTP failure while storing in flash.?
Would using the WCS be the solution?
Thanks in advance!
All responses will be rated.
Correct Answer by beabrams about 9 years 8 months ago
TFTPD32 is a free app that doesnt have the file size limit.
Overall Rating: 5 (3 ratings)
Correct Answer
beabrams Fri, 07/20/2007 - 09:53
  • Cisco Employee,
scottmac Sun, 07/22/2007 - 05:06
  • Green, 3000 points or more
3COM's 3cdaemon is also very good, easy to configure, and does not have the 32 MEg limit of most tftp servers.
Make sure you are using at least v2.0 (I think 2.10 is current)
It also builds in an FTP server, tftp client, and syslog server.
Caution: It has been shown to have some security holes, so bring it up, use it, then drop it. Don't leave it up as a permenent solution.
Good Luck
Scott
Anonymous (not verified) Mon, 09/22/2008 - 16:10
Anonymous (not verified) Mon, 09/22/2008 - 16:11
Anonymous (not verified) Mon, 09/22/2008 - 16:12
Anonymous (not verified) Mon, 09/22/2008 - 19:21
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
