Subnet translation problem
Jul 20th, 2007
I have two internet connections here, one is a T1 line connected to a Cisco 2800 series, the other is a DSL line connected to a Cisco 506-E which is used for a webserver and VPN traffic.
When I attempt to translate port 80 to the webserver on the internal network via the PDM, it says that it 'recommends I use X.X.X.0 instead of the full IP for the outside interface on the PIX.
The network is as follows:
IP Range:
IP Subnet:
2800 Series IP:
PIX VPN Pool IP Range:
PIX VPN Pool Subnet:
All the machines are configured to use the 2800 series as the main gateway.
The webserver is using the DSL line on a separate interface (it also uses another interface for network traffic because it hosts files).
I need to forward port 80 as well as a few others to the webserver, but leave its settings untouched.
If we could work a way out how to do this then that would be awesome thank you.
-Mike Jankowski
a-vazquez Thu, 07/26/2007 - 18:54
think there is no problem in IP subnetting. It is looking fine. But first make sure you clean up the sensitive information like Public IP Addresses.
But also I think, if the problem is with a single channel group, you have a potential interface problem and the problem is with the T1 line, or with all channel groups, you have a potential controller problem.
For more information please click following URL:
