Can't connect to peers on VPN Part 2
Jul 20th, 2007
I have two internet connections here, one is a T1 line connected to a Cisco 2800 series, the other is a DSL line connected to a Cisco 506-E which is used for a webserver and VPN traffic.
The network is as follows:
IP Range:
IP Subnet:
2800 Series IP:
PIX VPN Pool IP Range:
PIX VPN Pool Subnet:
All the machines are configured to use the 2800 series as the main gateway.
The webserver is using the DSL line on a separate interface (it also uses another interface for network traffic because it hosts files).
What I need to do and haven't be able to is make all the machines 'see' the PIX when a remote/ping request is made from the VPN. We had already determined that adding a route that would forward all request from the VPN pool's subnet to the router can be done on the 2800 series, but since I have no access to that machine we are stuck.
I would like any assistance if possible.
-Mike Jankowski
