07-20-2007 10:47 AM - edited 03-11-2019 03:47 AM
Whenever I apply change in HTTP scanning (url blocking, file blocking), the CSC module will reboot by itself. Is it normal? Below is the log i see when it happens.
1|Jul 20 2007 09:23:00|505013: ASA-SSM-CSC-10 Module in slot 1, application reloading "CSC SSM", version "6.1.1587.0" CSC SSM scan services are reloading because of a pattern file or configuration update
07-26-2007 06:47 AM
I think that CSC always reloads (not reboots) the configuration after a config change has been done. The log "CSC SSM scan services are reloading because of a pattern file or configuration update" only means that config is reloaded, which is normal.
07-26-2007 07:03 AM
Thank you. It just takes like a little longer to reload than I expected.
