thomas.chen Thu, 07/26/2007 - 06:47
  • Silver, 250 points or more
Note that this utility has also been made available for Linux systems. Because Linux does provide an agent UI, using the csactl utility on Linux is optional. Because the Solaris Cisco Security Agent has no user interface, a utility is provided which allows you to check the Solaris agent status, poll in to CSA MC and re-enable logging. The command you enter to perform these functions is csactl.
