Cisco PIX 515E Natting
Jul 20th, 2007
I am trying to enable Natting on a new Cisco PIX Firewall 515E but I have not managed. I have enabled both interface0 and interface1 but when I connect a cable from my Satellite modem on the ethernet0, there seem not to be any activity. I think I have configured all the IP addresses correctly but I can't manage to connect to the internet. I don't know how to get the PIX to use the gateway and route traffic from my inside net to the internet. I tried to used ASDM but when I loggin it says page can not be found and does not load the application.
Is this normal? Is there something I can do to enable Natting and connect to the net? I have managed to get the DHCP server working but that's as far as I have gone.
Philip.
sundar.palaniappan Fri, 07/20/2007 - 12:08
  • Green, 3000 points or more
Try adding this.
nat (inside) 1
global (outside) 1 interface
route outside 0.0.0.0 0.0.0.0
Sundar
purohit_810 Fri, 07/20/2007 - 12:16
  • Silver, 250 points or more
interface gb-ethernet0 1000auto
interface gb-ethernet1 1000auto
ip address outside
ip address inside
global (outside) 1 204.69.198.254
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 {Next hop IP address}
access-list 100 permit tcp any any
access-list 100 permit ip any any
access-group 100 in interface outside
If you have 7.X IOS ... than great to easy configure looks like Router.
Enjoy... Have a Best Week End.
Dharmesh Purohit
