access-list binding help required
Jul 20th, 2007
This is regarding SNMP config on 2980G Catos switch for ver 8.4.9
We have issued the following commands on the switch:
1)For SNMP Access list : set snmp access-list access_number IP_address [ipmask maskaddr]
I would like to know how binding of access-list are done and where when we defining for SNMP configuration
Arindam
purohit_810 Sun, 07/22/2007 - 09:18
  • Silver, 250 points or more
You can do by using following two commands
router(config)#snmp-server community MyCommunity972 RW 10
router(config)#access-list 10 permit 192.168.1.23
{Note: RW 10 that much be match with access-list No}
Dharmesh Purohit
royalblues Sun, 07/22/2007 - 11:40
  • Green, 3000 points or more
There is no binding required. The access-list number mentioned is referenced for all the SNMP inout packets.
Its something similar to using access-list when debugging or for PBR.
Narayan
