SSH on ASA5505
Jul 20th, 2007
I have an ASA5505 running ver 8.0(2). I have configured the ssh timeout, ssh host commands and did the crypto key gen. I am unable to access the device from the host I am allowing. Is there like ca save all command required? I am trying to use the default pix and telnet password. Do those still work?
l.jankok Sat, 07/21/2007 - 03:01
Try this:
username auser password secret privilege 15
aaa authentication telnet console LOCAL
mbutin Wed, 07/25/2007 - 13:11
For SSH you will need to enable a user and AAA on the ASA.
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
aaa authorization command LOCAL
Ramraj Sivagnan... Sat, 07/14/2012 - 22:40
  • Silver, 250 points or more
Hi Bro
Are you able to SSH into your Cisco ASA Firewall now? If yes, please do rate the above peer's comments k :-)
Firstly, if you're unable to access the Cisco ASA Firewall via SSH, can you PING the interface, assuming it's INSIDE, interface? If yes, then perhaps, could be your Terminal Emulation software. I use PUTTY, and I noticed if I were to use crypto key generate rsa modulus 768, this is good but not good if I choose 1024, for example.
Please do rate this comment :-)
