Copying disk0: to disk1:
Jul 20th, 2007
I have a Cat 6509 with a Sup720 card in it. I have two PCMCIA cards. One is running in the switch already (disk0) and the other is blank but formatted (disk1).
All I want to do is copy all of disk0 over to disk1. An exact copy of disk0 to disk1.
I don't want to have to copy each file and dir individually.
copy disk0: disk1: does not do it.
Is there anyway to do this? I am running Version 12.2(18)SXF6.
Any help would be most appreciated.
sundar.palaniappan Fri, 07/20/2007 - 15:59
AFAIK IOS doesn't give you the option of replication between PCMCIA cards. Unfortunately you would have to copy the files individually.
ryderse69 Fri, 07/20/2007 - 16:09
Hmmm. Thanks Sundar.
I was afraid of that. I have been poking around for the last hour or so trying to find a suitable command.
Bummer :-(
