Logging
Answered Question
Jul 21st, 2007
Hi.
We have a very interesting problem. Using KIWI as a syslog server, we are trying to record each and every time a user logs into a pix or asa device and ALSO every command entered. Is this possible via programming on the security device OR MUST it be done on syslog???
Thanks!
Correct Answer by Jagdeep Gambhir about 10 years 2 days ago
Hi Net,
Please mark this thread as resolved so other can benefit.
~JG
Overall Rating: 4.5 (2 ratings)
GRAEME DANIELSON Sat, 07/21/2007 - 22:07
These are standard in-built features of a TACACS service. If this is an option for you it will be far easier than trying to bend the syslog features do it
netsec123 Sun, 07/22/2007 - 06:09
Thank u so much.
Would u know of a freeware tacacs+ prod? We don't have cworks. :(
Cheers.
netsec123 Sun, 07/22/2007 - 06:46
Also, is there any way to record the show commands somebody enters as well..
GRAEME DANIELSON Mon, 07/23/2007 - 13:34
Yes, all commands entered are logged. You can get quite complex with login authentication and permissions too.
I have good success with tacplus from shrubbery.net if you're willing to get your hands a little dirty compiling in *nix http://shrubbery.net/tac_plus
If you're talking pure MSWin world, I have no idea sorry
Correct Answer
Jagdeep Gambhir Tue, 07/24/2007 - 04:57
  • Red, 2250 points or more
Hi Net,
~JG
