voice bundle order
Jul 21st, 2007
plz i need help because i am confused about the voice bundle:
1-when i order CISCO2811-CCME/K9 as bundle what are the version of the ccme come with this bundle and does the firmware files come with it. and how i know the ip phones supported by the bundle i buy
2- how does license work ? and what is license ? does it software or what is it exact ?
if i have phone 7911 and ccme software can i install the ccme on the router and the ip phone system work without need for license
thisisshanky Sat, 07/21/2007 - 20:28
  • Purple, 4500 points or more
It will come with the latest CME version if you order it Cisco direct. If you get it through a Cisco partner, they may get it eitehr Cisco direct or distribution and if you get their professional services, they will get it upgraded to the latest and greatest CME version.
The firmware files do come in flash, but if you have a particular phone firmware that you need, you can always download it from CCO Software downloads.
There is no license enforcement in CME, but you have to buy a license per phone. The part number is SW-CCME-UL-79XX. Where XX can be 60,40,61,71,70,11,12,05,02 etc depending on the type of phone you buy.
Hope that helps
Sankar
PS: please remember to rate posts!
