Secure desktop on ASA
Jul 21st, 2007
Does anyone know of a way that i can turn on Secure desktop for on group policy and not turn it on for another one? Meaning if i login as one group policy SD wont run, if i login as another it will download an run
Overall Rating: 4.5 (3 ratings)
ggilbert Sun, 07/22/2007 - 15:44
  • Cisco Employee,
On the group-policy you can not specify that CSD should be enabled or disabled.
But, on the CSD manager you specify a criteria to check by registry or IP address and if that fails, then you can attach it to a group-policy for that failure.
Cheers,
Gilbert
shaun.white Sun, 07/22/2007 - 17:31
Right...what i was asking was if someone knew of a workaround...if you cant pish a registry key to the machines, and they are internet VPN remote users, the IP address could be anything...so those checks go out the window...id think it makes more sense to say per group policy to enable or disable it...
ggilbert Mon, 07/23/2007 - 06:53
  • Cisco Employee,
Shaun,
CSD is enabled globally. So, when the webvpn page login is done, the CSD will be launched.
At that time, the CSD criterion is checked. On the group-policy, you can't configure this.
- Gilbert
