IP-Phone with notification for incoming call in display
Jul 21st, 2007
I am looking for a solution to solve the following issue.
I use CCME with Cisco IP-Phones 7931.I have about 30 Phones.
The phones have the numbers 101,102,103,??..
When there is an incoming call for e.g. number 102,all other other phones should get a notification in there display that this call is for number 102.
E.g. in the display of all other phones there should be a message like "call for 102"
Is this possible ?
Best Regards
Michael
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Sun, 07/22/2007 - 06:38
Try using a 'silent ring' button with the the extensions dn that you want to monitor, on the phones that you want to see the call.
This would become a shared line, be aware that if extension is dual-line, subsequent calls for that line, would go only to thephone thta has the first call.
If you are trying to do call coverage, best choice would be setting hunt-groups.
