07-22-2007 07:36 PM - edited 03-03-2019 05:59 PM
Hi all,
Can i configure the WIC-2A/S serial interface to 24.4kbps bandwidth? Will it be rounded up to 19.2kbps if i configure the bandwidth to 24.4kbps?
Pls advice.
Thank you.
07-22-2007 10:01 PM
Synch or asynch mode ?
I don't think you can have 24.4 Kbps in asynch mode. While it should be no problem in synch mode.
07-23-2007 12:21 AM
but base on datasheet, WIC-2A/S can support up to 128kbps for async and sync mode. That why i'm wondering whether can i specified the link to be 24.4kbps, or the serial bandwidth have prefix value, meaning that can only configure 2.4kbps, 4.8kbps, 9.6kbps, 19.2kbps, 38.4kbps....
Kindly advise.
07-23-2007 03:18 AM
Usually the asynch speeds are locked for common speeds, so I'm not sure that 24.4 is among these. You would need to try on an actual module.
07-23-2007 06:22 PM
Thanks for your advise. :)
