IPPhone displays manipulated number instead of the actual number dialed
Jul 22nd, 2007
I'm trying to configure CME(4.0).
When user dials to PSTN, IPPhone displays manipulated number instead of the actual number dialed.
I want to display original dialed number on IPPhone and I have to configure CME to select PSTN line.
If you have any suggestions, please tell me.
vmoopeung Fri, 07/27/2007 - 12:24
  • Bronze, 100 points or more
I think it is default behavior, If you call IPPhone to IPPhone it should display the correct number. Also try the following bug - CSCsd04254 for the above problem.
