Recover CSC SSM Using TFTP
jawad1979
I'm facing a problem upgrading CSC CCM module using recovery/re-imaging.
I tried different kind of tftp servers, all of them shows large file error msgs.
If anyone succeeded in this, can you please post the tftp server software name/brand?
Jawad
Yes. tftpd32 has worked for me for everything requiring a tftp server and the CSC module.
Are you directly connected to the CSC module or through a network? If not directly connected you may have a problem somewhere in the middle, try directly connecting to the switch attached to you CSC module.
I will look into this more on my setup.
Max
mbutin
tftpd32 works well for large files.
available at http://tftpd32.jounin.net/tftpd32_download.html
version 3.03 is the most stable I've used.
Thanks for the reply, I tried it, but it still fails. Have you tried it on a CSC SSM module before?
Jawad
Max
Thanks Max for your participation, I'll try a directly connected cable and post back the results.
Jawad
