Speed Dials on 7941/61?
Jul 22nd, 2007
Here's a simple one for you. When I set up Speed Dials on 7911G's, I can scroll through them using the Green UP/Down Arrow Keys. This feature doesn't seem to be in the 7941/61G's. In order to use the speed dials, I need to dials the number and press AbbrDial. This is fine but the User would then need to know all of their speed dials off the top of their head from the beginning.
Tim Smith Tue, 07/31/2007 - 02:31
  • Silver, 250 points or more
You have probably solved this already. But just in case.
7941 / 61's can have both abbr dials and speed dials. The speed dials on these phones are associated to the line buttons on the phone. i.e. 1 speed dial on a 41 and 5 on a 61.
However, you need to change the phone button template so that the buttons are set to speed dial instead of lines.
Then they should be available to set as speed dials.
Cheers,
Tim.
