Abt CCNA Certification
Jul 23rd, 2007
hi
I came 2 knew that new ccna curriculam will be introduced from Aug 1 and from November completely changed.I confuised with this.May i prepare for 640-801 or 640-801 ? Please suggest me in detail.
Overall Rating: 3 (1 ratings)
royalblues Mon, 07/23/2007 - 04:55
The New CCNA exam 640-802 will be introduced from 1st august.
But you can still certify to the old CCNA 640-801 till november after which you have to appear for the new exam to get your CCNA
I would suggest you appear for the 640-801 exam as it might take time to get the new books in stores if you are planning to take it soon.
http://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
Narayan
