3750 - Object tracking
Jul 23rd, 2007
Does anyone know if the 3750 standard image supports object tracking ?
I have 2 floors in a building with each floor having a single WAN link out to a mpls cloud.
I planning to have a L3 link between the 2 core switches on the 2 different floors and use static routing backup with object tracking for WAN link redundancy.
Has anyone tried this yet ?
Your help is much appreciated.
Paul
tbhagia Mon, 07/23/2007 - 01:04
Hi Paul,
Object tracking is supported in IP Base image
IP Base is a baseline set of Layer 2 and Layer 3 Cisco IOS Software services required to operate Cisco Switches. IP Base includes all the features of LAN Base, plus Edge IP Routing (Static, RIP, EIGRP-STUB & Basic PIM), HSRP/ VRRP, and GRE Tunneling.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/prod_bulletin0900aecd80281b17.html
Configuring and understanding object tracking:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a0080774458.html#wp1078647
Hope this helps! Please rate if you find the information useful.
Amit Singh Mon, 07/23/2007 - 01:16
  • Cisco Employee,
Paul,
3750 does supports the object tracking feature at this point of time. 3750's supports HSRP with enchanced object tracking strating from 12.2.25SE. 3750's also support PBR with enhanced object tracking. Please see the link below:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swhsrp.htm
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d1e95.html
3750's will support IOS IP SLA's in the new upcoming release and then you can use all the avialble functions.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080441596.html
HTH,Please rate if it does.
-amit singh
PAUL CHEN Mon, 07/23/2007 - 15:47
Amit,
I can't use HSRP because it is 2 separate LANs. So does that mean that object tracking alone is not supported ?
I suppose I can still use PBR with object tracking ?
Thanks for the reply. By the way, tell me how to go about rating your replies
Paul
Amit Singh Tue, 07/24/2007 - 04:43
  • Cisco Employee,
Paul,
You will see a drop down box " rate this post " on the right to my post. Please use the same drop downlist to rate as per your satisfaction.
BTW, Thanks for your efforts in rating the post :-)
-amit singh
