got a lot of ip address from command "show cable host access-group"
Jul 23rd, 2007
i issued command " show cable host access-group" at ubr 10012 and found a lot of cpe with ip address i use the command( clear cable host xxx) to remove entry. But dose anyone know the reason why ? how to remove it more efficiency ?
best regards.
uBR-10K#show cable host access-group
0016.cbf6.1e7f host
0017.4239.655a host
00e0.0609.0038 host
0002.8adf.de7c host
000c.6e64.a4f9 host
0030.0403.fd5d host
0090.0b04.2ae2 host
0000.0100.5adc host
0009.2ded.d4b7 host
000a.7998.591d host
000d.60e4.b091 host
0013.0220.3ff7 host
0016.4116.9ff1 host
0016.ec55.5776 host
0018.f35a.8b03 host
purohit_810 Mon, 07/23/2007 - 04:07
I think it shows you default route address.
But you can do one thing, by using Sniffer you can check out MAC addesss -> IP address.
Dharmesh Purohit
purohit_810 Mon, 07/23/2007 - 04:10 is belongs to source IP address.
Source IP address for the DSG stream. If an asterisk (*) appears as the source IP address, it indicates that the source IP address is, which allows any IP address as the source IP address.
Dharmesh Purohit
