Multiple slb-policy statements in a vserver
Answered Question
Jul 23rd, 2007
If I add three slb-policy statements to a vserver will all three policies be checked for each connection that flows through the vserver, or will the connection be set up based on the first matching policy, and the other policies ignored?
For example, if I have a vserver with two slb-policy statements: 1) policy with a url map which checks for the presence of *password* in the url and sends the connection to serverfarm PASSWORD; 2) policy with a url map which checks for the presence of *console* in the url which sends the connections to serverfarm CONSOLE, will the connection be passed to the PASSWORD serverfarm if the first policy is matched? Will the second policy be checked at all if the first policy is matched?
Thomas
Correct Answer by Syed Iftekhar Ahmed about 10 years 3 days ago
The order of slb-polies under vserver configurations is important.Policies under vserver are checked sequentially and whenever there is a match no further checking is done.
e.g.
vserver WEB
virtual 10.10.50.100 tcp www
slb−policy Policy1
slb−policy Policy2
slb−policy Policy3
In this case, if Policy1 has a match, Policy2 & Policy3 are not even considered, and the serverfarm associated with policy Policy1 is used.
Hope it helps
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Mon, 07/23/2007 - 10:19
  • Blue, 1500 points or more
e.g.
vserver WEB
slb−policy Policy1
slb−policy Policy2
slb−policy Policy3
Hope it helps
Syed Iftekhar Ahmed
