Adding NAT
Jul 23rd, 2007
This is my configuration, there are several options that I have to enable but... there is a doubt/problem.
If you see the txt configuration there are two adsl wic and two giga interfaces.
Gigabit1 connects lan to a lmds device and stablishes vpn tunnels. There is a ip pool configured (ips that I bought from my provider).There are 2 port nat 25/110TCP under atm01 interface.
Now I need to add several nats more under gigabit1 to lan.
I do not know how to configure the routes to do this...
Can anybody help me?
best regards
spremkumar Mon, 07/23/2007 - 03:22
are you planning to make use of the gig 0/1 to offer specific services ?
if thats the case you can try static nat on the router mapping the inside ip assiged onto your lan to the public ip assigned on the gig 0/1 interface.
Once you are done with that as you have already done for few services with Atm interface... you can acces the services from outside world..
