How to change IP Address/Hostname of CRS server?
Jul 23rd, 2007
Dear all,
I want to change the IPAddress of my CRS server and CCM server (CCM version 4.1(3), CRS version 4.0(5)) but I don't know how to do that. Could anyone give me some instructions on this?
(And, if possible, does the solution apply to CRS 4.5?)
Thanks very much!
hoanghiep
Gergely Szabo Fri, 07/27/2007 - 09:07
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
- CRS
-- hostname: bad news: this cannot be done. If you have SQL server installed, this just won't go. If you change the hostname anyway, then after rebooting the server the SQL server just won't start up. And you cannot even change it back to the original hostname, because it won't work either. So don't play with it.
-- IP address: no problem, just set the new IP address on the NIC configuration.
- CCM
-- hostname: change it using the standard Windows way. Then log into the CCM admin interface and change it there as well.
-- IP address: use the standard Windows way.
G.
hoanghiep Fri, 07/27/2007 - 18:03
By the way, Could I change the partner-CCM of the CRS server? (CRS server is working with CCM server 1, and now I want the CRS server to work with CCM server 2 (diffirent CCM Cluster)).
Again, many thanks,
Hoanghiep
Gergely Szabo Fri, 07/27/2007 - 23:51
Yes. I suppose by writing "partner-CCM" you mean the CTI manager and the LDAP repository of the CRS.
Use the /appadmin web interface of the CRS server.
- LDAP configuration: change IP addresses
- CTI: JTAPI subsystem> JTAPI provider: change IP addresses
thierry.berwart_2 Sun, 07/29/2007 - 23:03
Hi G,
Are you sure for the CRS ???
I think if you want to change the IP Address, you have to reinstall it from the CD and change the IP Address in the parameters because the IP Address is stored in many files used for the Cisco Agent Desktop, Cisco Administrator, LDAP ...
I will also check it
Thierry
thierry.berwart_2 Sun, 07/29/2007 - 23:21
I found the information : it was stored in the Cisco CRS Administration Guide 4.0(X), search for "Updating CallManager IP address Information", Page 8-45.
They explain what you need to change.
If the CallManager IP address changes, update the following information:
? CRS LDAP Information (if CRS uses DCD)
? CallManager LDAP Information
? RmCm JTAPI Provider
? JTAPI Provider
It was for the previous version (3.X) that you needed to use the installation CD's. sorry ;)
Kind regards,
Thierry
Gergely Szabo Sun, 07/29/2007 - 23:40
well yes, there is two things you need to worry about:
1. the LDAP repository IP address (~ CallManager)
2. the JTAPI provider IP address (~ CallManager)
Both may be (re)configured using the IPCCX web admin interface.
But again, I would strongly recommend to rerun setup if the hostname of the CRS server changes. I have no idea whether it is a bug or it is by design, but if you change the hostname, you will kill the MSDE/SQL server on the CRS, which is something you definitely don't want to do.
Yes, I tried it once, in our lab, and I was trying to troubleshoot it, without any success... Later I called a colleague at Cisco and he sort of confirmed it is the way it is supposed to behave...
G.
johnnylingo Wed, 08/01/2007 - 14:54
  • Bronze, 100 points or more
I think another good step would be to run postinstall.exe on the primary CRS server.
