Jon Marshall Mon, 07/23/2007 - 04:29
If you mean terminating on a firewall you don't have to open any ports as the firewall will allow IPSEC connections.
If you mean through a firewall
UDP 500 isakmp
IP 50 ESP
IP 51 AH ( note this is generally not needed)
If you need NAT-T then udp 4500
if you need IPSEC over TCP port 10000
Jon
