configuring active/standby cable based failover
Jul 23rd, 2007
i got 2 525 pixes with 4 interfaces. 2 of which are fast ethernet and 2 are gigabit. the pix also have a the serial cable for cable-based-failover
my configuration will be using all 4 interfaces for data traffic.
i want to use ethernet1 for my management and monitoring traffic and also for configuring failover.
i dnt want this interface to be dedicated only for failover.I m not going to use lan based failover, as i said i have the cable to do the cable based failover..
can i get this working, where my ethernet 1 ip wil be used in cable based failover configuration and also for my data traffic
secondly,i will use no monitor interface command fr ethernet 1
i.e failover not to occur if that interface goes down
finally, i will also use same security interface inter command. all my 4 interfaces will use same security level.this is only not to configure static and global nat..i will be configuing access-list to allow the traffic and block whts not permitted..in this case wht i have to allow for failover traffic
thanks
purohit_810 Mon, 07/30/2007 - 07:23
  • Silver, 250 points or more
failover link STATE Ethernet5
failover interface ip STATE {Ip address} 255.255.255.0 standby (IP ADDRESS)
Dharmesh Purohti
