Cisco Aironet 1200 - MIBS question
Jul 23rd, 2007
firmware installed 123-8.JEB
I use NET-SNMP to take information from AP's database agent.
I want the following information:
client rates (Mbps) - the current rate of
every client connected to the access point. For example for 3 clients -> 1Mbps,5.5Mbps, 11Mbps
I have searched all the supported MIBS from Cisco's website but i cant find anything...
Do i miss something??
Can you help plz...
Best regards,
Theodoros Dionysiou
irisrios Fri, 07/27/2007 - 12:34
There are no MIBs available > YOu can know the data rate from the client utility themselves.You can also use Protocol analyzer or link test on the client utility to know the data rates.
theodionys Fri, 07/27/2007 - 23:16
Hello again,
I have found what i needed.
CISCO-DOT11-ASSOCIATION-MY.my
Object : cDot11ClientCurrentTxRateSet
This object gives the information about the current rate that the access point sends data to the client.
I have tested this and it's correct.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
