Cisco Aironet 1200 - MIBS question
Jul 23rd, 2007
firmware installed 123-8.JEB
I use NET-SNMP to take information from AP's database agent.
I want the following information:
client rates (Mbps) - the current rate of
every client connected to the access point. For example for 3 clients -> 1Mbps,5.5Mbps, 11Mbps
I have searched all the supported MIBS from Cisco's website but i cant find anything...
Do i miss something??
Can you help plz...
Best regards,
Theodoros Dionysiou
Overall Rating: 5 (2 ratings)
jreekers Mon, 07/23/2007 - 18:52
  • Cisco Employee,
Hi Theodoros,
I think the closest you're going to get is this object:
.1.3.6.1.4.1.522.3.12.5.1.14
awcDot11TpFdbPreferredTxRate OBJECT-TYPE
-- FROM AWCVX-MIB
SYNTAX UInteger
MAX-ACCESS read-only
STATUS Current
DESCRIPTION "The transmission rate at which a packet should currently be transmitted from an AP to this Station.
This rate does not carry information about whether or not the rate is in the Basic Rate Set (i.e. bit 0x80 is never set)."
::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) aironet(522) awcVx(3) awcForwardTbl(12) awcDot11TpFdbTable(5) awcDot11TpFdbEntry(1) 14 }
In my research into this question, I haven't found an object that will specifically (within itself) give the data your asking for in that particular format.
I hope this helps,
-Joe
theodionys Tue, 07/24/2007 - 03:25
Are there any MIBS ( MIBS that are supported from different Cisco Access Points ), that will give the information i want?
Thanks , -Teo
theodionys Tue, 07/24/2007 - 04:47
[email protected]:/home/teo# snmpwalk -v1 -c demopublic 192.168.1.1 CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientStatisticEntry
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientCurrentTxRateSet.1."gstam-cisco".'......' = Hex-STRING: 16
cDot11ClientCurrentTxRateSet OBJECT-TYPE
SYNTAX OCTET STRING (SIZE(1..126))
STATUS current
DESCRIPTION
"This is the set current transmit data rates for
this client. Each client can transmit data at all
of its configured rates. There is a maximum of 126
it can configure to transmit. Each octet contains
an integer value representing one of these 126
rates it is currently transmitting. Each rate shall
be within the range from 2 to 127, corresponding
to data rates in increments of 500 kb/s from
1 Mb/s to 63.5 Mb/s. This value is reported in
transmitted Beacon, Probe Request, Probe Response,
Association Request, Association Response,
Reassociation Request, and Reassociation Response
frames."
::= { cDot11ClientStatisticEntry 1 }
is this object helpful?
jreekers Tue, 07/24/2007 - 18:27
  • Cisco Employee,
Hi Theo.
I believe it's a hex value of 16, which converts to 22 decimal. Each number representing 500kbps, so 22 decimal (16 Hex) corresponds to 11M.
Hope this helps.
-Joe
Trending Topics - Security & Network
