VPN Config
Jul 23rd, 2007
Hi. I'm trying to add a fastEth port to a VLAN of my 2900 series switch, using a vty connection by telnet.
The problem is: when I add this port to the vlan, the connection is dropped and I no longer can connect to the switch using this specific fastEth port. Why is it happening? thanks.
