Clear advanced sticky source ip sessions
Answered Question
Jul 23rd, 2007
I would like to clear advanced sticky source ip sessions every morning at 1am
is there a script or command to do this?
Correct Answer by Syed Iftekhar Ahmed about 9 years 10 months ago
The ip address in sticky-purge l3-sticky command is the clients IP address.
following are the show commands for Layer3 sticky database
show sticky-stats
show sticky-table l3-sticky
show sticky-table l3-sticky ipaddress 10.10.10.10
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Mon, 07/23/2007 - 10:05
  • Blue, 1500 points or more
You need to go into debug mode to purge the sticky entries
If you want to purge the entire table
CSS# llama
CSS(debug)# sticky-purge l3-sticky
To clear just one entry, specify the ip address and mask of the entry
CSS(config)# llama
CSS(debug)# sticky-purge l3-sticky 10.1.2.3 255.255.255.0
Hope it helps
Syed Iftekhar Ahmed
thumpercisco Mon, 07/23/2007 - 11:28
I can see 10 sticky l3 entries but I am not purging the right IP address nor doing a show with the right IP address.
Do I use the VIP address or the individual server IP's?
Is there a way to show IP's of sticky stats or the sticky table?
Thank you
Correct Answer
Syed Iftekhar Ahmed Mon, 07/23/2007 - 11:38
show sticky-stats
Syed Iftekhar Ahmed
thumpercisco Mon, 07/23/2007 - 12:03
Thank you for the clarification. I was looking to clear specific content IP sticky srcip sessions and remove all client connections at 1am every morning. It looks as though my only choices are specific IP's or global l3 stuck sessions.
Thank you
