changing interface
Answered Question
Jul 23rd, 2007
hello
there was a leased line 256kbps connecting two remote sites with serial interfaces. Today the leased line replaced with a fiber optic cable. the one serial interface remains on the side and the other side the Fiber ending into a switch converted to copper.
If we connect that ethernet cable into a routers ethernet interface is there any problem , is there any need of encapsulation protocol?that router leads to internet .
thanks
thanks
Correct Answer by spremkumar about 9 years 7 months ago
You can easily replace the serial interface with the ethernet interface which gives u the option of upgrade in a fly.
You really dont need to change any encapsulation...
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Mon, 07/23/2007 - 23:12
regds
