PBR and traffic treatment
Djule2804
I would like to know if it possible to apply treatment to a traffic flux before forward it in LSP in using PBR.
Treatment would be trafic measure, policing, shapping and tagging.
Could you show me an example of configuration where I could see this.
thomas.chen
Level 6
Level 6
Beginning in Cisco IOS Release 12.0, PBR is supported in the Cisco Express Forwarding (CEF) switching path. CEF-switched PBR has better performance than fast-switched PBR and, therefore, is the optimal way to perform PBR on a router.
No special configuration is required to enable CEF-switched PBR. It is on by default as soon as you enable CEF and PBR on the router
http://cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcpolicy.html
