vlan down
Jul 23rd, 2007
i have a switch 2950.
i create 2 interface vlan (1 and 2).
the problem is when i do "conf t" , "interface vlan 1), "no shut" the int vlan1 is up but vlan2 is down.
and the same with int vlan2.
i dont know what's the problem.
why they can not be up in the same time.
Overall Rating: 5 (1 ratings)
Edison Ortiz Mon, 07/23/2007 - 07:45
You are creating two Layer3 interfaces and this switch is only Layer2, hence it's a limitation in the hardware.
However, you are allowed to create multiple Layer2 Vlans but in order to perform inter-vlan routing, you need a Layer3 device (router or switch) connected to both Vlans.
Edison Ortiz Mon, 07/23/2007 - 08:13
They do but those IP addresses will never become active if the interface is down/down.
That's how the hardware limit its use. Only one Layer3 up/up at the time.
